about standard detail drawing
Hi fellow
I would like to ask, is there any standard drawing for detailing steel, concrete, etc. I means how should I present the professional drawing. eg. (weld a 10mm plate to be a compression stiffener). is it the text shows in the drawing would like (10mm PL STIFFENER, 5mmE48GP CFW TO THE WEB OF THE REFTER BOTH SIDE).
do anyone know where I can find some more information about drafting.
RE: about standard detail drawing
For Concrete - ACI has a detailing manual you can buy. Check out their website.  www.aci-int.org
For steel, AISC also has some books on detailing steel construction    www.aisc.org
For Australia, refer to the ASI publication:
  Syam, A.A.
  A Guide to the Requirements for Engineering Drawings of Structural Steelwork
  Steel Construction, Vol 29, No 3, 1995
  Australian Steel Institute (www.steel.org.au)
