Air/air vs Water/air intercooling.
Laminova (Opcon): http ://www.opc onab.com/i ndex.asp?l angID=1&am p;cID=15&a mp;spage=1
clain good performance and they are certainly an unusual thing to hold in your hand, with such slim fins and tight tolerances.
Can anyone suggest some shortcommings from such a design? How would such a system avoid the heat soak issues that afflict an air/air IC in motorsport?
RE: Air/air vs Water/air intercooling.
The air passages are necessarily circuitous. The air flows through a number of relatively long semicircular channels that each measure 0.3mm x 3 or 4.25mm. They do not claim low pressure drop on the air side.
Look closely at the last illustration in "intercooler.pdf". Notice how much smaller the cross- sectional air flow area at the cooler entrance is than the cross- sectional area of the intake manifold in the illustration. I.e., the packaging density that suits the technology well to liquid- liquid cooling may not accrue in liquid- air cooling. The intercooler application appears to be conjectural; I'd expect a developed version to occupy substantial volume.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
Take a look at Titan-lite.com
Extremely accurate, with the benefit of filling the hole unlike the cylindrical units from Laminova.
