Specific Sliding - Internal gear
I am looking for specific sliding calculation formulations for external pinion meshed with an internal gear. First when the pinion is the driver and second when the internal gear is the driver.
Any information regarding a book/artice that has the formulation and theory for this case willl be much appreciated.
For external pinion meshed with another external gear I have found the info in KHIRALLA's book. However, for external gear pinion meshed with an internal gear I could not find any detailed information.
RE: Specific Sliding - Internal gear
israelkk,
you can find the formulae in DIN standard (I believe it is DIN 3960) and also in some publications, one of them is the MAAG company's gear handbook (Swiss company, I saw that booklet in German and in English; The same applies to the DIN standard).
The DIN uses the same formula for both external and internal gear pair. There is the value "u" in the formula. "u" is the no. of teeth ratio, always the larger divided by the smaller, therefore u>1
For internal gear pair the "u" value is taken negative and used in  the same formula.
FYI: Din is using certain data (no. of teeth, pitch dia...) of internal gear as a negative value. That way there are not separate formulae (or formulas?) needed for int/ext gear calculation.
gearguru
Thanks, I do not have the DIN by I can get Maag book.
You will find the formula in
Dudley's Handbook by Townsend,
Second Edition,
pages 12.7 and 12.8
Thanks diamondjim, however, you know how difficult it is to get a hold of this book.
The book is available at many
University Libraries.
Call me at 330 678 0226
and arrange how I can send
you a copy of these two pages
as jpeg files.
It is also available in the
Gear Handbook by Dudley
First Edition
pages 14-5 and 14-6.
Thank you again diamondjim, I have this book, I didn't find it because I could not find the "specific sliding" phrase in the index.
I know, the index is not the greatest.
