Open a file
Open a file
Open a file
Hi I am writing a script that will perform some calculations on a matrix that is in a file. I am stuck on opening a file that is inside of a variable. Instead of trying to open the filename in the variable it tries to open a file called var... How do I fix this? Thanks
RE: Open a file
You need to use the functional form of "load" try "help load" for more information.
M
Dr Michael F Platten
