load at failure
load at failure
load at failure
Hi everyone,
I am trying to determine the load on a bar at failure.  I know how to determine this at room temperature from looking at some old books, but this occured at elevated temperature.
Can anybody tell me where I could find proper material properties at working temperature?  The material is a common form of steel.
RE: load at failure
The ASM Metals Handbook Vol. 1 "Properties and Selection Irons , Steels and High Performance Alloys" has the data you require for many of the commonly used steels.
RE: load at failure
If failure occurred at elevated temperature it could have been caused by Stress Rupture which typically takes some time at a lower stress than that causing Hot Tensile Rupture. Failure analysis might provide some hints.
http://www.welding-advisers.com/
