bending sheet metal
bending sheet metal
bending sheet metal
I just started a new job working for a company that designs generator enclosures and fuel tanks (sheet metal drafting). I was wondering how to figure out the amount of material I need to remove/deduct in order to make a box out of sheet metal w one open end. I got the bend deductions down, but don't know the formula to figure out the amount of material I need to remove in order to bend the sides up to 90 degrees and have no overlapping/sloppy corners..
Is this right???
Notch = Flange(outer dimm.) - Bend Deuction - Percentage of material thickness and that should give ya a box at the right dimms.
Thanks for the help -Nick
RE: bending sheet metal
You can find a treatment of blank layout for square or rectangular shells at page 192 of ASM Metals Handbook Eighth Edition, Vol. 4, Forming, in the Chapter on Deep Drawing.
http://www.welding-advisers.com/
