Evaluation feature with in an Assembly
I am in the process of doing some stress calculation on the bearing surfaces of two mating parts of an assembly. I need to determine a tangent point and angle at there point of contact. I was/am able to flex the model and take a measurement of these two parameters. I was wondering if any has created an evaluation fetaure to "kick" this value out evreytime I make a change to the assembly.
I know this can be done in Pro/E, has anyone done this within solidworks????
On a sort of related topic, can the user be prompted for design inputs to flex a model? Again, this can be accomplished rather easily in Pro/E through a program and dimesional callout......
Thanks in advance for yor help....
RE: Evaluation feature with in an Assembly
Also, for user prompted inputs, you can get quite creative with design tables.
