ACAD2000 paperspace Dimensions
I'm ready to pull my hair out here. I'm a new user to autocad and can't figure out why my dimensions are different in paperspace than in model space. What am I missing here. Where do I set a scale factor and how do I make it 1:1?
Please help
Jason Bender
RE: ACAD2000 paperspace Dimensions
To set the scale of a viewport:
mvsetup
scale
follow the directions from there
R2000 was not as good at snapping to objects in model space through a viewport, but it still should work.  In theory, it is simple.  Draw full size 1:1 in model space.  Open a viewport in Paper space.  Zoom and pan around until you see what you want.  It does not matter what the zoom factor is.  Then freeze the viewport and turn ucsfollow off.  While in paper space, create a dimension using snaps to objects in model space.  It should be 100% accurate and should update when and if the model is changed.  IMPORTANT: Make sure dimassociate is set to 2.
first create your vport. from paper space double click inside the vport so you are in floating model space and type the following.
z (return)
s (return)
1/50xp (return)
the 50 above is an example of a scale, and it can be changed obviosuly to whatever scale you require. after doing this you should use the pan command to locate your drawing in floating model space, dont use any zoom cammand as this will upset your scale and you will need to redo your scale command.
then to set the dimension scale to this new vp in paper space you must leave the vport layer on and type
dim (return)
dimlfac (return)
then the command line tells you what the dim scale is set to so just type v and click on whichever vport you want dimension off and the dimscale will jump to the scale of the vport, hey presto.
remember if you have different vports at different scales, you will need to carry out this dimlfac exercise every time.
hope this helps.
regards, conskee
1. In model:
   Create drawing in 1:1
2. In layout:
   a) Create viewport and set up scale what you want
   b) in model space: use "z"
   c) in paper space: use "mvsetup"
Note: pay attention about your dimension and text height.
Good luck.
