Solidworks to ProE
Solidworks to ProE
Solidworks to ProE
A long time ago (2004?) i was able to save a Solidworks drawing in ProE form (.prt). I am now running SW2005 SP2, and the help screen still says that i have that option but it does not appear in the "Save As" menu.
Any ideas will be appreciated.
RE: Solidworks to ProE
Drawing or solid?  I can save a solid as .prt in "ProE" format.  SW 2005 SP1.1.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Drawing. i can save parts and assy's as ProE with no problem
I beleive you can only with solids.
If you look at the "save as" formats between part, assy & dwg, you will see differences.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
You can save as dxf and import that to ProE, but that my not be what you are looking for....
Thanks for all your inputs. I believe you are all correct in what you say. Now, if i can only convince my customer.....
thanks again
