Strange lines appear with hole wizard
After putting a 3/8 pipe tap into the side of a casting, long dashed lines appear in the model. The hole is in a boss but it breaks out on the curved wall of the casting. That might be the source of the problem.
The thread and hole appear normal when viewed directly on, and the isometric view is normal. But in any of the orthogonal views a very long dashed line shows up. The line is several times longer than the part. I think it is where the tap drill breaks out. The pipe thread itself is contained within the thickness of the wall. Turning off the cosmetic thread made no difference.
The line also shows up in the drawing views but it only extends to the edges of the part and not beyond it as it does in the model. There has been no problem with other holes, but they break out into flat surfaces.
Maybe it is just a glitch. I can always hide the lines on the drawing.
RE: Strange lines appear with hole wizard
Does turning off "Draft quality HLR/HLV make a difference?
I think this my fix your issue.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
The drilled hole breaks out into the intersection of a curved wall and a corner fillet. By zooming way in, there was one little piece of the thread that broke out and this must have caused the cosmetic thread display to go nuts. I backed off slightly on the default depth of the pipe thread and that fixed it. You probably can't do that in a real part without changing the fit of the pipe thread, but at least the picture is ok now.
