Coating of carbon fibre epoxy pipe line in sea necessary?
Is an extra anti-corrosion coating on a carbon fibre filament wound pipe line, used on a sea depth of about
3000 m, required? And if so, what would be a good material?
many thanks in advance
Tom
Tom
RE: Coating of carbon fibre epoxy pipe line in sea necessary?
What will this be connected to? Remember C is very stable and you can get some serious galvanic interactions.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Steve Jones
http://www.pdo.co.om/pdo/
