Sub drains after the fact?
I have a neighbor who has notice increased amount of moisture coming up through the concrete slab up to his hardwood floors. With the way his house was build and where it is located, that portion of his house should have sub drains under the slab, but does not. Any suggestions on what to do now? Can we trench, say 1' under the slab and 5' into the house from the edge to help move the water which I think would be less intrusive or is it even possible to have him remove the wood floors and cut the slab do a sub drain now? I don't even know if either suggestion would help. Not a groundwater problem. It is from all the crazy rain that we've been getting here in LA.
Any suggestions?
Any suggestions?
RE: Sub drains after the fact?
