how detect key wear for turning machine ?
Hello
i made a measurement on a spindle machine with keys to fixe gears on the shaft spindle.
and i have a 155Hz peak with 2 side bands of 38,8Hz
the turning speed is also 38,8Hz.
Dou you think it could be key wear ?
regards
zzlinks@hotmail.com
RE: how detect key wear for turning machine ?
Only if there are four keys.
Look for something square.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
i will check for something square or 4 keys
thank you very much
I think it could be key wear.
It sounds like you have harmonics of 3x, 4x, 5x of running speed.
Impacting at 1x such as from looseness can generate a series of harmonics peaking near resonance of the component being impacted.
