Linear Bearing Problem
We have a problem with linear bearings failing on one of our projects.
From 4 - 1" Open Linear Bearings (Ball bearing style)I have supported a structure which weighs approx 500lbs. From this frame I have a long set of forks (aluminium extrusion) that extend approx 8' beyond the frame the bearings are mounted to. On these forks a very light load is applied (sheet of fabric).
Bearings are mounted open side up ie suspended from rail.Bearings are rated at 2800 lbs each (static)
This frame is manually pushed by the operator as part of the process.
PROBLEM: even though we have cushioned limit stops, and the operators are trained to be "gentle" the shock to the bearings as the backstops are encountered cause bearing failures almost weekly. Plastic housing which holds the Bearing balls in place are being subjected to repeated hammering by the balls, ultimately punching through and breaking down.
I have spent quite a bit of time trying to locate a "super" bearing that can withstand these forces. We have also looked at better stops & cushions, but feel that the answer lies in the bearings.
Hoping that one of you guys out there can recommend a bearing manufacturer, or provide useful tips to solving my prob.
THANKS in advance!!!!
RE: Linear Bearing Problem
How does running a linear bearing open side up as you describe change the bearing's capabilities? I'm not saying you did anything wrong, just curious as I have not seen this before!
Yep, I did look at Pacific - their bearings are pretty much generic, in fact the 1st set I used were Pacific, and then went on to use Thompson. It is documented that there is no load capacity difference up or down.
My main problem is the catilevered load, and the associated "leverage" on the bearings combined with the shock effect, when the back stop is contacted.
I am now looking at...
a) methods/techniques to protect the bearing from the shock loads, rather than beefing up the bearings. ANY idea appreciated
b) Frelon type bearings - Unfortunately, although coefficient of friction is similar to ball bearings, the initial inertia required to move from start is much greater. - so some ideas to overcome that problem would also be MUCH appreciated.
Great group - keep up the good work!
Most of these are adjustable.
Can the bearing assembly be modisfied to mount the assembly on disc springs (Schnorr / Belleville / Ringfeder) or rubber mounts.
you also getting a moment load
which compounds the loading?
Russell Giuliano
Unique Technologies Associates - Cobra Solid Lubricant
www.uniquetechnologies.com
Danaher Motion brand is Thompson, while IKO brand in Tompson. The number of rows allows for better centering, however for your use likely not critical, as more rows or higher alloy stainless steel for chemical resistance adds cost to make. 5-6 row all metal will work for ~$20 more.
