Need some advice
Need some advice
Need some advice
Im trying to make a drill but having problems with the wheel carry-out from the relief.
Im doing it by using swept boss.
heres what im talking about...
http://jessemeza.netfirms.com/Temp/index.htm
RE: Need some advice
You could do a seperate cut-revolve at the abrupt end of the sweep in the "Bad Drill" example. That would simulate the cutter run-out.
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
