WWTP background
3
WWTP background
WWTP background
I am an electrician, I used to work on power plants. At present I am working on electrical part of waste-water traetment plant, I would like to learn about technology-how it works and etc..I am looking for any links or literature which can help me understand this technology.
Thanks a lot!
RE: WWTP background
The it is worthwhile buying them following book if you want to learn about wastewater engineering:
"Wastewater Engineering: Treatment . Disposal . Re-use" by Metcalfe and Eddy (McGraw Hill).
RE: WWTP background
The Water Environment Federation is a good starting point.
http://www.wef.org
RE: WWTP background
If you are working at the WWTP, one of the plant staff should have a copy of Operation of Wastewater Treatment Plants, Volumes I and II.  These are great books if you're just starting out in the wastewater field and are the basis for many wastewater treatment plant operator certification programs. http://www.owp.csus.edu/wastewater.htm  Good luck.
