Tip to reduce file size and help performance.
Hey guys, ran across a tip to help reduce file size and increase performance recently. I tested it and in some cases part file sizes shrank 10-50%.
In Tools, Options, Systems Options, General there is an option to "save e-drawings data in file". Well apparently at one point e-drawings could not read native SW data so it stored it in the file. Having this option on will result in an approximate increase of 10-30% on file size and also effect saves & rebuilds. In the future this option will be removed as now Edrawings no longer requires it to be check since it reads native SW file data.
Give 'er a try and see what changes ensue.
RE: Tip to reduce file size and help performance.
Before any upgrade, I always go through all of the options (don't trust that the defaults will be optimal for your use!)
Does anyone out there have a use for this setting?
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
