Need Some Advice
Need Some Advice
Need Some Advice
I have justa BSc in Computer Science and Electronics with Lower Second Class honours at the University of the West Indies, in January 2005. What are the names of some Universities that would accept me for  with my current qualifications to do Masters degree (MSc) in a field that is electronics and communications oriented . What are some Masters programs i could be qualified to do base on my current qualifications.
This is a list of the course that i did:
Circuit Analysis, Digital Electronics, Microprocessors, Circuit Simulation, Discrete Device Electronics, Control and Instrumentation, Digital Signal Processing, Microcomputers and Control, Digital Communications, Calculus
Computer Programming, Discrete Mathematics, Information Structures, Computer Architecture, Software Engineering, Operating Systems, Design and Analysis of Algorithms, Object Oriented Programming, Database Management Systems
RE: Need Some Advice
Any school that you apply to will take a look at previous coursework in order to see how well it meshes with their degree program.  They may decide to accept all or part of your previous work as credit towards an advanced degree.
Best suggestion I could make is to contact any university that holds interest to you and see how well you "fit" with their programs.  Think more on the areas that interest you and see what the universities have to offer along those lines.  Electronics and communications are still some pretty wide areas.
Hi kenalex,
Masters degree program admissions are usually based almost entirely on your grade point average and the reputation of your undergraduate institution.  Approximately what is your GPA?  If I know that, I can probably give you some good schools to consider.
Good luck!
My GPA is approximately 3.33.
Hi Kenalex,
Definitely check out the Fulton School of Engineering at Arizona State University.  They are an up and coming EE program, and are quite reasonable to get into right now.  I think you would probably get in there with your GPA.
Here is a link to their webpage:
http://www.eas.asu.edu/~eee/
They have an MS program that includes a thesis, and an MSE program that is only coursework.  They have programs in both comm and circuits.  You can also complete your entire coursework online, if you want, in case you don't want to move out to Arizona.  They have invested a lot of money in their online program and have modeled it after Stanford's program.
Another school you might want to consider is the University of Washington.  They offer a pretty top notch EE program, which is MUCH easier to get into than say MIT or Stanford.
http://ee.washington.edu/
Hope that helps!
thanks alot
I checked over my GPA and it is 2.9 and not 3.3.
Sorry for putting you through this trouble rustin03.
Can you tell me any university courses that offer masters in my field of interest with my current GPA.
Most graduate schools of engineering typically have a 3.0 or higher GPA cutoff. I guess this is because anything less than a 3.0 is not considered a passing grade at most grad schools. You should check your "in-major" GPA, and if it's higher than the cutoff for the school to which you are applying, emphasize it in your application letter or essay if one is required.
Also, you may be conditionally admitted to a school and on probation for a while if you have less than the required GPA when you apply. This allows them to make sure you can earn the grades required to continue in graduate school. Check with the departments of the colleges you're considering, and discuss your situation with their department heads or departmental graduate admissions coordinators. They'll be able to give you more guidance, since each department typically has the last word on who is admitted to their graduate program.
xnuke
"Do you think you used enough dynamite there, Butch?"
Does Any one know of an gradutae school that offers MSc programs in any Electronic/or electronic engineering field that would accept a BSc in Computer Science and Electronics (with Lower Second Class Honours)( GPA 2.9).
Thank you
Kenalex
