sectional view
sectional view
I have a block for example with a temperature field. I want to cut the block in the middle to get a view of the temperatue inside through thickness, just like taking a section cut in the middle. I have ansys 7 and couldnt find any options for doing that. I am not sure if I missed it. Does anyone know if that option is available or is it in the newer versions only? Any comments appreciated.
harry
harry
RE: sectional view
There is two command:
/type,1,1 ! To define section view
/cplane,1 ! To define cutting plane with the working plane
JanJ5
