Remote machine room disconnect
The door to the machine room is not visible from where the motor controllers are (you must walk to the end of a hallway, turn left and then go up some stairs to another level where the controllers are located).  Are two disconnects required?  One near the door and another within site of the motor controller?
RE: Remote machine room disconnect
This was recently discussed. Check out:
Thread242-117363
David Baird
mrbaird@hotmail.com
Sr Controls Engineer
EET degree.
Journeyman Electrician.
