Alternative to marine transmission
Marine transmissions are usually high-priced and low-volume.
I was wondering if they can be substituted with high-volume low-cost car/truck-type automatic (or manual) transmissions, provided engine/transmission/prop driveline geometry permits
RE: Alternative to marine transmission
The main modification is to remove the torque converter and replace it with a direct drive, as the propeller acts as quite a high stall speed torque converter.
pat pprimmer@acay.com.au
