Wildfire 2 screen flashing
We have noticed that when shaded, the screen from time to time
was flashing causing a certain effect on the user (BAD)!! The
culprit is the popup help(that yellow box showing what you are highlighting). There is a config option to prevent this from popping up. "enable_popup_help" which by defaylt is yes. This
shuold be NO
shuold be NO
Joe Borg
www.methode-eur.com
RE: Wildfire 2 screen flashing
Another thing that might help when spinning a large model (especially if it contains complex molded/cast parts on the outside). Is to use Edit-->Select-->Preferences and turn OFF preselection highlighting. This way a mouse-over doesn't cause the computer to highlight each part in light blue (and thus really slow things down)...
Great tip.
Mark
As of now, the option of preselection highlighting from "justkeepgiviner" is working, but time will tell. I'll let you know if it keeps working.
Chris Chase
