ROPS -rollover protection systems
Anyone have any info on modeling the ground contact event in FEA or any info on surface contact perameters, e.g., concrete?
RE: ROPS -rollover protection systems
You could probably get an idea with a coefficient of friction (steel on concrete) of 0.3, and a surface compliance of (WAG) 5000 N/mm
Cheers
Greg Locock
Is this a roll over hoop, in which case you could probably get away with a simple beam element model in ADAMS? or is it the seat back pop up headrests, in which case I'd suggest a flex model in ADAMS, or LS DYNA. As you know, the crash guys use the latter.
I've never done any serious impact stuff, that's interesting. Have you got any test data to look at or are you flying blind?
Cheers
Greg Locock
Heavy truck problem-class 8 semi's No data at all that's the problem. Probably go with external tublar steel 4130 or better, ~ 100k tensile. This " surface compliance of (WAG) 5000 N/mm " is not quite clear. Is this penetration resistence. What kind of indentor? Is the material presumed to fail if you get beyond this -what's the resistance past this failure point?
No, WAG=wild ass guess for the stiffness, which I don't think will affect your result on second thoughts. I don't think good quality concrete will fail in your scenario.
ADAMS will give you a good idea of the impact laods in your bar, but you should feed those loads into a proper FE program if you are interested in the structural stresses, or you can do the whole job in one hit (hoho) in LS DYNA.
Cheers
Greg Locock
SAE has standards you need to adhere to. The standards are for physical testing.
http://
best of luck,
buddy
RCE
