Help building a test box
Need help in assembling a test box using off the shelf parts if possible. Simplicity in training someone to use would be a big plus. What the box needs to do is cut AC power (110vac) to a unit under test 10 milliseconds after a trigger (source is 12-24vdc) is applied. AC power would then be reapplied so a tester could document what happened on power up. The test would be repeated increasing time after trigger in increments of 10 milliseconds until a total of about 4 seconds is achieved. Any help or suggestions would be greatly appreciated.
RE: Help building a test box
could you clarify it?
The problem itself seems to be simple .
<nbucska@pcperipherals DOT com> subj: eng-tips
read FAQ240-1032
I need one test box that could trigger from various transaction systems used in a kiosk. The embedded systems operate from 12 to 24 volts DC supplied from the kiosk. What I need to do is kill power to the kiosk at various time intervals after a transaction is started and document results when power is reapplied.
The test would be as follows:
? Triggering from transaction system number one, kill power to the kiosk 10 milliseconds into a transaction then reapply power and have results documented.
? Triggering from same device, kill power 20 milliseconds into transaction, reapply power and document results.
Each test would add additional 10 milliseconds before killing power.
I would assume a digital timer capable of triggering from a 12 to 24 volt DC signal is needed. A solid state relay could then be activated to kill the AC power. I have searched some catalogs but seem to be having problems putting this together. Again any help is appreciated as I come more from a mechanical background.
0 = lamp is off, = on etc.) or record a phonebook of 2000
pages...
In any case the simplest seems to be using a PC with a SSR.
read FAQ240-1032
if you want flexibility in the timing patterns and repetition.
Then take the dc logic output to an ac switching SSR such as:
http://www.power-io.com/products/dda2540.htm
A zero crossing SSR turns on and off at the sinewave's zero mark that occurs every 8.3 milliseconds. Therefore, if you tell it to turn on, it will wait till the next zero mark. There are "random firing" SSRs, but then there are additional electronic noise issues to be addressed.
Off the shelf hardware, meets electrical codes when properly installed, easy to program, using a local engineering school for assistance is a great idea.
