Alternative to PDM Works?
So, here's the deal. Can't seem to convince the people making the final decision to buy, that PDM Works is worth it. I know, and you know otherwise. So I've been asked to solve the problem by other means. Here's the kicker, we have MatrixOne which is has a horrible interface and just needs to be activated (of course custom installed, setup, and training required). I don't think there is a sustitute for PDMW, but does anyone know any others? Has to be Cheap! Thanks,
Doomed.
John
Doomed.
John
RE: Alternative to PDM Works?
http://ww
I can't give any recommendations though ... I've never used any of them!!!!!
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
If you want something good and cheap, you can use ACCESS to create your own PDM. That's what we use at my company. It works very efficiently. But of course, you need to know ACCESS first.
Alex
As for access, I've thought of it, but it's another DB that someone will need to setup, implement, maintain, etc. and that just not in the plan.
It's a struggle.
J
Alex
Do not worry, our management made the same mistake. We could not afford SmarTeam for everyone. So the drafters got a seat each. We had three floaters for the Designers, the Engineers got none. What happened was we lost more in engineering dollars than PDM Works would have ever cost us.
The Engineers would copy whole assemblies out to the net work, so that they would have the models when they needed them without having to find a drafter to get them the latest. What happened was the drafters had to re-mate all assemblies before putting them into SmarTeam using the model out of SmarTeam to make sure they had a released latest model.
Bottom line: Time is money and lost time is lost money.
Bradley
ht
