Pro/E 2001 Sketcher auto regen
When in sketcher mode, with Intent Manager on, Pro/E 2001 regenerates the sketch everytime I modify a dimension. This a major pain when the new dimension is much different from the one generated by Intent Manager. My 2000i student edition allowed me to regenerate all of the changes at once - after I was done. Is there a check box or config file entry that will delay regeneration?
RE: Pro/E 2001 Sketcher auto regen
Nikhil Gothankar
This is probably a more robust way of resolving your problem, as delaying the regeneration can cause other problems.
Andy
