Need to protect SS with non-conductive paint
Does anyone know where I can find a non-conductive paint to use on a stainless-steel sheet metal (1,5mm thickness)?
We're producing prototypes of a shield and the customer asked to cover this SS with a coating of non-conductive paint to prevent flow of current.
Sorry for my bad English
Ciao, Grazie
Renato
RE: Need to protect SS with non-conductive paint
Any special environmental restrictions? (chemicals, water, temperature)
How much dielectric strength do you need?
There are some very good epoxies out there.  That is where I would start.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
You need to talk to your customer on how much non-conductivity he needs. What amount of voltage is he shielding. Aerial devices used by power companies per ANSI require 70,000 volt protection which is unattainable using paint.
