How to write PRNSOL output to a file
I'd like to write a macro file that performs some PRNSOL commands on different components and, instead of having the results in the usual popup window, I'd like to have them directly in a txt file to use in other applications.
My ideal macro should than be:
cmsel,s,comp1
PRNSOL,U,SUM
<command to write to file1>
cmsel,s,comp2
PRNSOL,U,SUM
<command to write to file2>
Can anyone help me?!?!?
Many many thanks in advance
Al
RE: How to write PRNSOL output to a file
No problem:
cmsel,s,comp1
/output,comp1_output,txt     ! redirect output to a file called "comp1_output.txt"
PRNSOL,U,SUM
/out
cmsel,s,comp2
alls
/output,comp2_output,txt
PRNSOL,U,SUM
/out
The above will only work if you read the file in using the
/input
command or from
File > Read input from
So make sure you save the above in a separate text file and read it in.
Cheers,
-- drej --
Thank you very much, Drej.
After I wrote my question, I tried with "/out,file_name" too, but I missed to execute the macro: I only copied-pasted the lines into command line, and obviously in that case it doesn't work...
Too much work, not enough coffe!
Al
