Residential Material estimate (Takeoff)
I have been asked to do the take off for a 3000 sq ft new house, anyone has the item list or excel sheet that I can use or has any recommendation. This is my first time doing it.
RE: Residential Material estimate (Takeoff)
I recommend getting estimates from other local builders and compare their prices. Get more than 3 and determine how long they have been in business. This will tell you whether their numbers are good or not. If you are still determined after this to come up with your own version of the costs to build, send me an email and I will quote you a cost for an excel spreadsheet to help with estimating costs. It is not a small undertaking though.
500 2 X 4 – 104 5/8” (9’ Precut) Pine
300 2 X 4 – 104 5/8” (10’ Precut) Pine
200 2 X 4 - 14' Llp
40 2 X 4 - 14' Pt #2 Above Grade
8 2 X 6 - 10' Pt
2 2 X 6 - 16' Pt
500 1 X 4- L.Ft Syp
4 2 X 12- 10' Syp
20 2 X 12- 14' Syp
3 6 X 6- 10' Pt
2 6 X 6- 12' Pt
24 2 X 6-14' Llp
4 1 ½” X 11 ¼”- 16' Gluelam
4 1 ½” X 11 ¼”- 18' Gluelam
80 4 X 8 ½” Osb
160 4 X 8 15/32 4 Ply
6 4 X 8 5/8 Decking
28 Felt #15 Astm D4869
5 Dow Sill Seal 50’ x 3 ½”
18 Hd-2a Hold down Zmax Simpson
36 5/8" X 4" Bolt Plated
5/8" Nut Plated
5/8" Washer Plated
100 3" X 3" X 1/4" Washer
3 Boxes 1/2" Plywood Clip Simpson
600 Hurricane Straps Z-Max Ssth25z Simpson
30 2" X 6" Joist Hangers
42 18" Straps Galv
100 Sp4 Strap Simpson
5 6x6 Post Cap Zmax Simpson
4 Pocket Door Frames
1 Pull Down Stairs 10'x 22"
