Parallel port on PC
Parallel port on PC
Parallel port on PC
Quick easy question - it's quicker for me to ask than to dig out a buzzer and bell it out.
Does a standard parallel printer ("Centronics") cable have any sort of 'cross' in it?  I want to plug a dongle into the back of my PC, and I'm getting a bit sick of ratting around the back of the box every time I want to remove it.  (I share it with somebody else).  So I had a brainwave - keep the cable permanently plugged in, and just plug the dongle into the cable.  But if there are any x-overs, this won't work...
Bung
Life is non-linear...
RE: Parallel port on PC
Any DB25 extender cable that really has 25 wires inside will work.  I'm saying this because there are DB25 extender cables for serial cables, and these only have seven wires.
Shopping tip - Normal 'Centronics' printer cables, 6-foot, intended for PC to printer, are only Cdn$2.00 (about US$1.65 ) at the local bargain stores. They've got every wire, are shielded, and appear to be of good contruction quality. I mention this only because some places still ask as much as Cdn$30 for a similar cable.
A word of warning!
I have had problems with dongles not working when placed at the far end of an extender cable.
On the other hand, I do currently work fine with three different dongles after each other and then a printer cable out the back of my PC.
Most standard 'centronics' printer cables have different connectors on each end. The PC end is normally a 25-way D-type (which most dongles will fit). The other end is a 'Centronics' propritory connector
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
Just make a flat ribbon cable assemnly with the required sex DB25 connectors at each end for a couple of bucks.
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
