ZFB Relay Test Kits
ZFB Relay Test Kits
Hi
Can someone please provide information about the ZFB test kits ? These were old methods to test the relays i believe. But i would really appreciate if someone could provide information on different methods to test relays including the ZFB test kit ?
Thanks.
Thanks.
RE: ZFB Relay Test Kits
It was made by GEC - you might be able to get some information from your local Areva agent (GEC's latest name).
GEC used to put instructions for using the ZFB in their distance relay manuals - for example the Quadrahmo.
These instructions are quite easy to follow and apply to any distance relay type.
However compared to the test sets used today, testing a relay using this set is very slow.
thanks.
If you don't know who your local Areva (or Alstom) supplier is - try www.areva-td.com/contactcentre/ and send them an e-mail request
The ZFB instructions publication should have exactly what you need.
