Control of kerozene's conductivity mesurment apparatus
HI
need method to make à solution (KCl solution for exemple) to control(calibarate)the JET A1 fuel( kerozene) conductivity's mesurment apparatus "MAIHAK", the conductivity's range is: 0 to 600 picoSiemens/meter,
I have not standard solution, so i thaught to do as we do for the water conductivity's mesurment apparatus, which we control by KCl solution using convrsion table (KCL concentration, conductivity value), but i dont know if it'is right to use this method's for MAIHAK apparatus,
if yes ...........what is the KCL concentration needed for 0 to 600 PS/M conductivity's range.
RE: Control of kerozene's conductivity mesurment apparatus
m777182
