PDM works server references.
We are just getting started with pdmworks.  I just loaded some select assys into pdmworks on a dedicated server.  When I try and open and resolve the assy it is reaching back to the old server location for the file definition, If I delete the old files there is nothing there to resolve, pdm works is not trying to open the files from the new server, when I loaded the files I had my VAR here and he set up everything, (I have sent him an e-mail as well) we got no errors etc.  What gives, anybody elese seen this type of problems.
TAP
RE: PDM works server references.
When you login to PDMW, do you have the correct server name displayed? If not, change it there.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
When I log in I am seeing the correct server.
TAP
You should only have one vault. Backup, copy to new vault, then remove the old one. Have IT dept redirect everyone to new one.
Chris
ctopher's home site
TAP,
From my understanding, PDM server has a name, let’s call it “Stanly”. On your network you cannot have two servers called Stanly. I believe SolidWorks puts everyone’s server name onto the CD’s. This means the name you originally gave your server will have to be the name of the server. To test this idea, name your server as the original. Then remove the old server off the network.
Good luck,
Bradley
I'm not sure if this the same thing but here's my penny's worth....When I'm using PDMW, I turn off "Search file locations for external references", TOOLS>>OPTIONS>>SYS OPTIONS>>EXT REF's. Although PDMW checks out the assembly and its referenced parts to your check out folder, its my understanding that SW will still try to resolve the assembly references, that were saved in the file before it was checked in. Turning off this option in SW stops it from searching these "old" locations. The search order is outlined in the SW2004 "File Management" training manual. Page 45. If you have a filepath to a project folder on the server defined in FILE LOCATIONS>>REFERNCED DOC's, it could be getting the parts via this?
Where are you having your files saved when you open or check out?  It doesn't sound like a PDM Works issue, more of a I'm not using my local hard drive to work on files?  Take a look at that.
John
I think I found the problem, my system was opening the assys lightweight, when it resolved them it was looking back at the old location.  I had removed the files from the old location and changed the setting to open the assys resolved from pdmworks and everything seemed to be fine, my VAR is checking to see if he can duplicate the problem.
TAP
Where do make the change to resolve assembies from PDMWorks?  I am having the same trouble that when I check out a file from another station it can't find references.
It sounds to me like some or all of the references in your assembly are not being checked out with the assembly, therefore they don't exist on your hard drive, therefore Solidworks is finding them in the last place they were found.  PDMWorks is a file management tool only, opening and resolving files is done in Solidworks, hence Solidworks settings would apply to those operations, not PDMWorks settings.
Solidworks has an algorithm it uses to resolve references, which you can find in the Help under "Searching for Referenced Documents".  (though PDMWorks tweaks these references somewhat to look in the folder you download the file in to before it looks in the last place the files were saved).
The first thing I would try in order to fix your problem would be to trace the steps in that document and figure out at which point the files you want to check out are not being found.
