Smoke Detector Requirements - 2000 IMC
In Chapter 6 (Duct Systems) Section 606 of the 2000 International Mechanical Code, there is an exception that states the following:
"Smoke detectors shall not be required where air distribution systems are incapable of spreading smoke beyond the enclosing walls, floors and ceilings of the room or space in which the smoke is generated."
The way I see this, they are making an exception for single zone systems that cannot develop a positive pressure in the room -- that is, they either do not take in outside air, or they exhaust more than they bring in.
Does anyone have an experience with this exception?
---KenRad
---KenRad
RE: Smoke Detector Requirements - 2000 IMC
Also, you can't use a common return plenum with any other space, either!
