Brooks Hansen 2 pole motor coil grouping
Hi Guys,
i would be appreciate some advice for the rewinding of a Brooks Hansen Motor. The motor carries 12 coil sets in groups of 4, can anyone assist me a coil connection for 2 pole arrangement.
RE: Brooks Hansen 2 pole motor coil grouping
Hi Glen
    Any more details..I assume 3ph....have you got 12 groups of 4 coils.. I would have expected 6 groups.
            jeff
      www.motors-direct.co.uk
If you are attempting to change the speed of a 4 poles motor, details of the actual nameplate, winding and goal parameters (HP, Voltage, and Torque) are required. Some mechanical analysis is required in regard to the bearings, fans and stress of rotor materials.
Most probably at least a complete new winding is required.
glensleep, you must also supply the dimensions of the lamination - in particular the bore size, o/d and slot depth.  It may not be possible to convert from 4-pole to 2-pole because of saturation in the back-iron, this generally needs to be twice as deep in a 2-pole motor - if there is insufficient depth then the motor will overheat and not develop full torque.
THIS IS A 48 SLOT MOTOR AND IT IS 4 POLE.YOU ARE TRYING TO CHANGE IT TO 2 POLE.YOU WILL NOT GET A SATISFACTORY RESULT AS THE MOTOR IS DESIGNED FOR 4POLE.HOWEVER THE DETAILS WILL BE -GROUP OF 8COILS , HALF SLOT COILS, 6 SETS
HOPE THIS WILL BE OF VALUE.
THANKS
thank you all for your great advise. i will put some into operation on the 10 Mar. when i start the rewind. will keep you all informed.
thank you.
