Flow Meter Vibration Frequency
If a pump is vibrating with its blade passing frequency in the range of the 200~400Hz and this pump is located 5ft away from a flow meter with its natural frequency around 200Hz, how much higher should the natural frequency of the flow meter be increased to avoid resonance problems?
RE: Flow Meter Vibration Frequency
Cheers
Greg Locock
