Detail Views
Detail Views
Detail Views
Question:
I want to place a detail view on a different sheet than the Parent view. Is this possible. If so can someone point me in the right direction.
TIA,
Adam
RE: Detail Views
cut and paste to new sht. Search in this forum, it has been discussed before.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
RE: Detail Views
Ive have tried that. Didn't work. I've done it with views and it's worked before but never a detail view. I got a dialog box that said "Cannot copy this item from the clipboard".
I'll keep looking.
Adam
RE: Detail Views
Once created on a sheet you should be able to go to the feature manager and drag it to the sheet you want it on.
Best Regards,
Heckler
Do you trust you intuition or go with the flow?
RE: Detail Views
In the Drawing View Manager you can simply "Drag & Drop" from one sheet to another. (SW2004)
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
RE: Detail Views
Drag & Drop worked......thanks.
Adam
RE: Detail Views
I have SW2005.....dragging detail view from sheet 1 to sheet 2 does not work.
How do you do this in SW 2005?
(is the view locked or someting like that?)
thanks,
ken
RE: Detail Views
Ken1,
I just moved a detail view to sheet 2.  I don't think a locked view would have anything to do with a detailed view.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 3.1 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
      o
  _`\(,_
(_)/ (_)
"There is no trouble so great or grave that cannot be much diminished by a nice cup of tea"  Bernard-Paul Heroux
RE: Detail Views
ken1 ... Make sure the sheet you are moving the view from  is active and when you drop the view, drop it on or immediately below the sheet title  of the sheet you are moving it to. If you try to drop it on or below the Sheet format  line, it will not work.
RE: Detail Views
Drag and Drop in the feature tree.
Jason
