Combisensors (Rogowsky Coils)
Question:
I would like to receive some feedback about your experience using
Rogowsky Coils instead of CT's.
Currently, we are participating in a project where Rogowsky Coils are
used with a ratio of 80 A / 150 mV.
My main interes is knowing:
Which is the ratio that the current is converted in secondary amperes?
I mean 150 mV are equal to X Amperes?
This is our "key point" in order to do the protection settings.
Any assistance will be welcome!
RE: Combisensors (Rogowsky Coils)
Is it for high current measurements where an ordinary iron core would saturate? Or in applications with higher order harmonics? In that case I can understand your choice, but for standard protection I think that I would prefer normal CTs.
What does the manufacturer say?
http://www.rocoil.cwc.net/principle.htm
Flexible coils are commonly used for portable instrumentation.
http://ww
For a sinusoidal current,under steady state conditions the voltage is:
Uout= M*j*ohmega.Ip
The signal is a sinusoidal voltage, proportional to the
current, with 90º phase shift (lead).
rgds
I know that Rogowsky sensors are transducers and their secondary side
has a voltage signal. However, my main concern is related to the
settings of the protection devices that are receiving signal from the
Rogowsky coils.
In order to setting the protection relays the reference is usually In,
that could be 5 or 1 A (secondary rated of the CT's)and in this case, we
do not have secondary amperes, then:
Which is our new reference to perform the settings?
Shall we take into account the current rating of the Rogowsky coil? (in
this case 80 A)
Best Regards
You would normally expect a ratio of 1000A:5V.
