Circle Sketch Default, Radius Only?
When creating a circle sketch SW2004 asks for a Radius dimension by default.  Is there a way to change this to ask for a Diameter by default?
Thanks in advance,
Cygnas
RE: Circle Sketch Default, Radius Only?
I don't think it can be changed.
I usually ignore the dialogue box size & set the size by placing a diameter dimension instead. If you just use the dialogue box, the circle is not fully defined.
Eng-Tips.com Forum Policies FAQ731-376
Making the best use of this Forum.  FAQ559-716
How to get answers to your SW questions.  FAQ559-1091
Helpful SW websites every user should be aware of.  FAQ559-520
I think it will dim with dia, unless the circle has been trimmed or cut somehow.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP1.1 / PDMWorks 05
ctopher's home site
