Shaft breakage
Shaft breakage
Would 4140 Cold Drawn be a good material used in a 1 inch shaft that needs to withstand 30,000 Lbs tensile strength and also stand up well in a 45 degree bending moment? If not any sugestions? I know the tensile is no problem.
RE: Shaft breakage
Dave
RE: Shaft breakage
Cory
RE: Shaft breakage
RE: Shaft breakage
Let me know your results.
-mechantaeus
RE: Shaft breakage
RE: Shaft breakage
Best Regards,
Heckler
Do you trust your intuition or go with the flow?
RE: Shaft breakage
