Get Value By Name? (SWAPI)
You can set properties and other values, such as dimensions, to notes via SW Addressing, For example:
DWG Number:    $PRP:"SW-File Name"
Scale:        $PRP:"SW-Sheet Scale"
Current Sheet:    $PRP:"SW-Current Sheet"
Total Sheets:    $PRP:"SW-Total Sheets"
Weight:        "SW-Mass@@Default@partnum.SLDASM" LBS
But is it possible to set these values to Variables in VB...
Such as:
CODE
Dim X as String
X = Y("SW-Mass@@Default@partnum.SLDASM")
Where Y() is the qualified function that retrieves the values from SolidWorks, and assigns to X...?
If this is confusing, please say so, and I will try to clairify...
Thanks in advance,
-Josh
When dealing with computers, there are 10 things you need to know: one, zero, and the rest is Binary.
-Josh S
RE: Get Value By Name? (SWAPI)
Please do clarify.  I am confused...
Evan T. Basalik, MCSD
It's all about prioritization...
as far as the notes in a SW Drawing go...
you can make a reference to other values by using strings to reference them...
such as...
If your File is named "12345.123.slddrw", and you place:
  $PRP:"SW-File Name"
in a note, the note will display: "12345.123"
If an assembly (12345.123.sldasm) weighs 123.5 lbs, and you place:
  "SW-Mass@@Default@12345.123.SLDASM" LBS
in a note, the note will display: "123.5 LBS"
My question is if there is a way to get these values the same way via VB, to set them to a variable rather than display them in a note...
For use with a Form, or exporting them to a text file, etc...
-Josh S
Have you tried CustomInfoValue?
I have the same problem.  I can't find a way to directly access the file name in VBA, but you can use the CustomInfo to link it.
In the drawing template, under the Custom tab in Summary Info (accessed from File->Properties), add a File Name (or whatever you want to call it) property which links to the SolidWorks file name property using $PRP:"SW-File Name".
In the VBA code you can then just access the file name value by setting a variable equal to swModel.GetCustomInfoValue("", "File Name").
This seems like a bass-ackwards way of doing it, since that file name property should already be available somewhere already, but it does work.
Have you tried swModel.GetPathname?  That will get the fully-qualified file name.
I use this code to get the file name from the path name
CODE
    Dim swApp                   As Object
    Dim swModel                 As Object
    Dim swDraw                  As Object
    Dim sFileName               As String
    Dim sPathName               As String
    Dim nErrors                 As Long
    Dim nWarnings               As Long
    Dim nRetval                 As Long
    Dim bShowMap                As Boolean
    Dim bRet                    As Boolean
    Set swApp = Application.SldWorks
    Set swModel = swApp.ActiveDoc
    Set swDraw = swModel
    sPathName = swModel.GetPathName
    sPathName = Left(sPathName, Len(sPathName) - 6)
    sFileName = swModel.GetTitle
    sFileName = Left(sFileName, Len(sFileName) - 9)
Here is a fancy way...
Throgh this in a macro and run it...
CODE
Sub main()
  Dim FullName As String, FileName As String, FilePath As String
  With Application.SldWorks
    FullName = .ActiveDoc.GetPathName
    FileName = Split(FullName, "\")(UBound(Split(FullName, "\")))
    FilePath = Replace(FullName, FileName, "")
  End With
  MsgBox "Full Name: " & FullName & vbCrLf & _
         "File Name: " & FileName & vbCrLf & _
         "File Path: " & FilePath & vbCrLf
End Sub
Minimum variable useage... No objects declared
Enjoy,
-Josh
-Josh S
And for the Name without extention...
CODE
Sub main()
  Dim FileExt As String, DrawName As String
  With Application.SldWorks.ActiveDoc
    FullName = .GetPathName
    FileExt = Split(FileName, ".")(UBound(Split(FileName, ".")))
    DrawName = Replace(FileName, "." & FileExt, "")
           "File Path: " & FilePath & vbCrLf & _
           "File Ext: " & FileExt & vbCrLf & _
           "Model Name: " & DrawName & vbCrLf & _
           "Title: " & .GetTitle
  End With
End Sub
Note that you can also use ModelDoc.GetTitle but for drawings, it will return the sheet name as well...
So, if you just want the Drawing name, Do this...
DrawingName = Split(ModelDoc.GetTitle & " - ", " - ")(0)
-Josh S
