How I can implement a matrix inversion using Gauss-Seidel Method ?
Hi guys,I need to implement one VB 5.0 aplication, witch decoy a imagem jammed to the same imagem, but clear now. I will use a calculus with two matrix, calls Matrix_A and Matrix_B, right ? Well, I can't use the matrix invertion, using the Gauss-Seidel's linear system calculation method. How I can implement a matrix inversion using Gauss-Seidel Method in Visual Basic 5.0 ?
Thanks for all !!!
