AC wiring similar to Versatrak
I am in need of a 4 foot section of 3 AC conductors (110v -12a) that are flat and can have a wheeled device driven over it that has a weight of 100 lbs. The conductors will be driven over by a plc controlled motorized rubber wheel similar to a lawnmower as many as 300 times a day. Any Ideas????
RE: AC wiring similar to Versatrak
Any cable isn't going to last. You can make a guard or buy one.
Hubbell makes a rubber track for crossing a floor or a driveway. Look at their catalogue. Heres a couple of links. Your local electrical supplier probably has this stuff in stock.
http://www.hubbellcatalog.com/wiring/datasheet.asp?PN=FT2Y10&FAM=CPP&P=841,847,535
http://www.hubbellcatalog.com/wiring/datasheet.asp?PN=HBLTRED5A&FAM=CPP&P=909,11139
Additionally, you may visit
http://www.thomasregister.com
and type Cables: Electric under Product / Service which will return 446 companies to inquire about a right cable for your needs.
