Horsepower for vacuum operations
I just ran a case in 3 different vendor programs, the Cooper-Bessemer equation, and a couple of different adiabatic horsepower equations that has me baffled.
With a constant discharge pressure of 80 psig (at 6,000 ft, so 92 psia), a constant suction temperature of 70F, and a constant flow rate of 150,000 ft3/d. I changed the suction from +5 psig (17 psia) to -5 psig (6 psia) and the horsepower requirements went down. Compression ratios went from 5.4 to 15.3.
It is obvious to me that all of this arithmetic is intended for positive psig to positive psig (in fact one of the compressor manufacturer's had a disclaimer that their horsepower calculation had "significant error" with a vacuum suction).
Does anyone have an equation that is reliable for a vacuum suction?
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The Plural of "anecdote" is not "data"
RE: Horsepower for vacuum operations
That doesn't explain the compressor manufacturers though.
David
