Tig Pulse Welding
Tig Pulse Welding
Hi, can someone give me a quick rundown about pulse welding when using the TIG process , (AS i have never used it yet), what are the usual frequencies between pulses? and what is the current difference between the high and low peakes?, and what are the advanteges of using this type of welding?, is it recommended for DC TIG Welding or really just for AC?, thanks
RE: Tig Pulse Welding
Ask the guys that build the welders.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Thanks and regards
Sayee Prasad R CEng MWeldI MIOMMM
If it moves, train it...if it doesn't move, calibrate it...if it isn't written down, it never happened!
