Infrared cameras in automotive racing.
I was reading a book on race car design and the autor talked about how he dosent know exactly what temeratures tires reach while corners. He guessed aound 700 but wasnt quite sure. I was thinking infrared cameras could be used to monitor tire temeratures while a car is in motion. Has this already been done? I know tire manufactuars use infrared to test tires and use it to check for warning signs of tire failure aswell. I figure it woud also show where the tire is gripping the most and help with suspension tuning. Any thoughts?
RE: Infrared cameras in automotive racing.
However, infrared temperature measurement is notoriously inaccurate in real-world situations. For many materials -- and I bet rubber is one of them -- emissivity changes with temperature.
It would probably need to be kept well away from the direct IR radiation exhaust pipes, brake rotors and other very hot objects.
I see no reason why a commercial tyre heater could not be used to test and verify the system on a stationary vehicle.
Buy one of the remote IR temperature sensors that measure heating duct outlet temperature and take it apart.
Best regards,
Matthew Ian Loew
Reading the temperatures on the tire can give a wealth of information on suspension, geometry, a lot more. I think that some racing endurance cars have infra red sensors built into the car, and they are used primarily for safety reason, to detect the rapid heating of a tire, usually indicating a tire losing air pressure.
(By the way, Patecell was a Pan-Am pilot who originally aimed his insert for airplanes.)
Cheers, Brett.
