Converting Pro-E to Solidworks?
I have a client that has a medium sized assembly in Pro-E.
We are going to make an option for his product so tp speed up our development they have sent us thier assembly in IGES and Step formats. I couldn't open the STEP file and the IGES files is a collection of surfaces, no solids at all. Any thoughts? Are any formats better than others for this task?
This is my first time attempting this so I could also be overlooking a very basic step.
RE: Converting Pro-E to Solidworks?
Best Regards,
Heckler
Do you trust you intuition or go with the flow?
You said that you tried to imports STEP files and couldn't open them. I always use STEP or IGES file when I receive files from a client. When opening IGES files make sure your knitting setup is active so it can create a solid body.
In STEP mode make sure that your client as exported the STEP files with one of the following format: D203, D214, C214.
You can also try to open ProE files directly from Solidworks, I usually have problems loading the assembly but the part are opened with mo problems.
What version of Solidworks are you working on?
I have tried importing it several ways and it doesn't work. I think it's a combination of very little experience at both ends. and the assembly not exporting correctly.
Have you tried to open the *.prt.1 ProE files directly?
I know I always have problems opening an ProE assembly but the files are OK.
Try sending me an IGES,STEP and ProE file.
colombo75@hotmail.com
I think it's cool that solidworks can export proE parts and asemblies but why proE cannot do the reverse is just absurd...
s
I use Pro/Engineer WF2.0 and SolidWorks 2005 everyday, and i import stuff from pro-e everyday, weither it's an assy or just a part.
Tools->Add-Ins-> {check Feture Works} and bring your parts and one by one SW will convert every entity created in WF to make it editable in SW. Hope that helps.
Printed Circuit Board Designer
Salt Lake City, Utah
No Substitute for american muscle !
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
