Year Date plus one
Year Date plus one
Year Date plus one
I want to copy all of the dates in a column in excell
but add 1 year to the dates and have it appear in the next column. I tried =H1 + 1 and several other ideas but
the day changes by one.
RE: Year Date plus one
Try "+ 365".
You could try the following formula
New date is J1
=DATE(YEAR(H1)+1, MONTH(H1), DAY(H1))
Good Luck
As a circle of light increases so does the circumference of darkness around it. - Albert Einstein
Unless it is a yeap lear :)
Wheels within wheels / In a spiral array
A pattern so grand / And complex
Time after time / We lose sight of the way
Our causes can't see / Their effects.
Oh, you'll have to watch out for leap years as they'd be a day off in that case.
Four replies inside two minutes...  I'm glad they've added the time to the posting date.
CC's answer is best.
Make a custom function using VBA and use the VB "Dateadd" function.
Excel's internal date serial number format is based on the number of days since 1/1/1900 or somesuch thing.  The fraction is the elapsed portion of the day since midnight.
That's why adding 365 will mostly work.  A more complicated scheme would involve decomposing the actual year, month, day, adding 1 to the year and reconstructing the date serial number.  That's assuming your goal is to get the same date, only 1 yr later.
TTFN
That worked perfectly.  Thanks!
Thanks for your other ideas as well
+ 365   and + 366 for the leap year
would work but caution would be required
or an if statement included.
