Silicon Bronze or Aluminum bronze in brackish water
A cooling tower manufacturer has proposed using silicon bronze bolting and trim in cooling water service containing 16,000 ppm chloride, 1 ppm H2S and 3 ppm ammonia at approximately 80F. Pressure from atmospheric to 60 psi. Does this selection appear feasible?
RE: Silicon Bronze or Aluminum bronze in brackish water
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Thanks for the quick reponse. I felt that Al Bronze, NiAl Bronze or Monel were good choices without resorting to Ni-Cr-Mo alloys. With the high price of Ni and Mo these days (I just received info of an approximate 15% increase in Ni the past week) NiAl Bronze would certainly be more economical.
The brackish cooling water is well water and I believe H2S should out gas when depressurized. Bolting is primarily connecting fiberglass components. Stress on bolts will not be high.
11 003 Nickel stainless steels for marine environments, natural waters and brines - Guidelines for selection
11 004 Materials for saline water, desalination and oilfield brine pumps
http://www.nidi.org/
Steve Jones
Petroleum Development Oman LLC
Muscat
Sultanate Of Oman
