Guarding & Anti-kickback alligator shear
I need ideas for guarding and an anti-kickback device for an alligator shear used for shearing rebar.
Discover the role technology plays in supporting transformation and the importance of Engineering and Manufacturing collaboration
Download NowINTELLIGENT WORK FORUMS
RE: Guarding & Anti-kickback alligator shear
All these things will point you toward a solution.
The "pure" solution is to prevent the machine from moving while any body part is in it's path; or you can think about it as making sure no body parts can be in the machine's path during it's operation.
For a simple solution, maybe consider vertical plates parallel to the shear on either side of the shear with thin openings for the rebar, big enough for rebar, but to small and/or too far away from the shear for body parts.
good luck!
